Galaxy S2X battery dying quickly
I sent my phone in for repairs because my battery drained really fast. I had a new battery sent to me and the same thing happened so I sent it so that they could fix whatever problem I was having. I got my phone back, they said they replaced a part and it was fine now. Got it back and the next day it died after 8 hours and i only used it for maybe 3 hours throughout the 8 hours. Will they resend it to see if there is a problem or am I just going to have to get a new phone. I have the Galaxy S2X and it is under warranty until April 22 so I need something done.
As long as the phone is under warranty, you can keep asking for replacement batteries.
8 hrs is not an unusually short battery life for an android phone. These tips should help: http://www.wikihow.com/Save-Battery-Power-on-an-Android (Tip number 2 will not work on Koodo since they have no 2G network)
Timo Tuokkola wrote:
8 hrs is not an unusually short battery life for an android phone. These tips should help: http...
They cleared my tab since it wasn't fixed when I sent it in. Now I get a new phone.
