Galaxy Ace2X and SD card
My son has a Galaxy Ace2X. I bought 16GB SD card for him but it didn't work at all. Now he got a 8GB SD card from his friend and it is working fine. Is there any reason? or do I have a defective phone?
Have you tried the card in other devices? Mire likely the card us faulty.
DID you format the new 16gb card in the phone?
I'm not tec person,,,I have no idea. He just tried to figure it out and he couldn't. I wasn't sure if it is a phone or card problem. There is no other issue with it ,just SD card.
Yes,his sister tried and it was working.(She has a same phone) Also his friend trid and it was working so he basically switched SD card with him.
Seems odd but I would return the old card and get another one. See if it works. If not then it might be time to arrange for warranty service if the phone is under a year from its purchase date.
Chad Burr wrote:
Seems odd but I would return the old card and get another one. See if it works. If not then it mi...
He switched SD card with his friend so he doesn't have an original 16GB card. I got this phone about 5 month ago. I will check it out. Thanks
