fixing a charger connection port on a samsung a5 phone
  • 28 January 2021
  • 4 replies
  • 54 views
i have a samsung a5 phone which won't connect to charge. i think its a physical issue with the port in the phone. it’s soldered to the motherboard, so the klinik won’t be able to fix it. does anyone have any short term solutions so i can retrieve the files from my phone before replacing it? or any recommendations as to who might be able to fix the port outright? thanks in advance.
Best answer by rikkster 28 January 2021, 23:42
I would recommend a third-party repair shop, the Galaxy A5 is pushing six-plus years old. There’s a cellphone repair shop in your area. Give them a call or send them a message via Facebook Messenger and see what they say. The shop mentions quick turnarounds for repair, (same day service).
https://www.facebook.com/thecellphoneshop/
It's basically a solder fix. Samsung can fix it. Or third party if you're willing to risk forgoing your warranty if it's been under a year. Without juice you're Sol to backup. It's gotta be powered on.
Thanks. i know it needs to be powered on to backup, i just wasn’t sure if this was a common issue and someone knew of some sort quick way to power it up somehow. it’s out of warranty by now, i wasn’t sure if a place like best buy does this sort of thing. i’ll def contact samsung though. thanks again for your help!
Thanks rikkster! That’s what I did and the phone should be ready wednesday or thursday
