Excellent call quality and data speeds
Userlevel 3
I have been enslaved by Bell for 12 years and moved to Koodo a month ago. I can safely say the call quality is excellent (maybe subjectively better than Bell, using the same Note3) and on LTE I hit 90Mbps download... I also like the usage tool (still needs some work on mobile) and in general the self-serve features. I'm definitely the type of customer that never calls in if a web solution exists...so I don't care about Koodo charging for unwarranted calls. [b]All I want at this point is for Koodo to implement the equivalent of Telus Extend...I really NEED that feature. I hope I won't jinx it with this praise 🙂
Hi there, thank you for your feedback! It's appreciated 🙂 As for the "Koodo Extend", you should suggest it in our idea section! We review all of them: http://koo.do/1oCGna3 🙂 Have a great day!
Userlevel 3
It is posted in the Ideas section...not much traction though. I bet this would make a LOT of Koodo customers happy: http://community.koodomobile.com/koodo/topics/will-koodo-be-offering-something-similar-to-the-upcoming-telus-extend-feature-allows-talk-and-text-on-wifi-with-laptop
