essential phone repair cost
  • 4 November 2018
  • 851 views
hey i recently just cracked my phone screen. phone is working just fine. i know that the repair owuld have to cost 200 $, usd even, and they don't even ship to canada. is there any way i can repair it at a much lower cost?
Best answer by Mats 4 November 2018, 04:26
You would have to call your local repair shops to see what they would charge. It would probably be pretty close to $200 Canadian if they could do it.
You can find a replacement screen on amazon.ca for around $100 if you're willing to try yourself. Not the easiest to do.
https://www.ifixit.com/Guide/Essential+Phone+Display+Replacement/105122
Or if it's under 3 months, your credit card comapny might have something called Purchase Security and Extended Warranty Protection
That was for manufacturer warranty extension and some insurance for first 90days. The OP broke his/her screen, that wasn't covered under warranty.
Or if it's under 3 months, your credit card comapny might have something called Purchase Security and Extended Warranty ProtectionThat was for manufacturer warranty extension and some insurance for first 90days. The OP broke his/her screen, that wasn't covered under warranty.
And that's also if you paid for the entire phone upfront. Not for a phone on tab
Pour yourself a beer, get out your hanky and read:
https://www.engadget.com/2017/09/05/essential-phone-teardown/
Interesting. iFixit claimed at one time that the only way to remove the display from the Essential PH-1 was to freeze the device. Yet, the company suggests using the following tools; a heating plate pad and/or heat gun. iFixit has since revised the method for removing the display.
https://www.ifixit.com/Guide/Essential+Phone+Display+Replacement/105122 - (scroll to Tools section)
Warning: Because of the strong adhesive securing the display, minimal clearance for inserting your tools, and very high heat required, there's a good chance of accidentally damaging the display during this procedure. If you're replacing a broken display, then you don't have to worry—but for all other repairs, work very carefully, and be prepared to replace the display afterward if necessary”.
Essential Phone Teardown Repair Guide
https://www.youtube.com/watch?v=BCKxAQXdTJ8
iFixit Essential Phone Teardown
https://www.youtube.com/watch?v=cruSzcdmhls
Essential Phone Teardown - JRE
https://www.youtube.com/watch?v=2fZ-qIHlA5M
