enabling mobile data
hi. i wanna enable my data on my phone. coz i disabled it when i purchase this plan. i wanna enable it now. how am i going to do it? even if i will turn on na mobile data. it wont work
What phone do you have?
S3
Log into self serve
Go to your Plans and Add-ons
There should be an add-on called Data Block.  Just remove it
Dennis wrote:
Log into self serve
There should be an add-on called Data Block. &n...
Okay! Ty
Does the new Self Serve allow customers to add/remove Data Block from it? Last I know it doesn't. If it does, then you're good to go. If it doesn't, call customer service and they won't charge you since you can't do it.
Jonathan I wrote:
Does the new Self Serve allow customers to add/remove Data Block from it? Last I know it doesn't....
Thank you.. ill try and if i cant ill phone them . Thanks
