does the lg g5 have a fm radio tuner enabled chip?
  • 1 February 2017
  • 11 replies
  • 2378 views
I would like to get this phone as long as the lg g5 has a fm radio tuner enabled chip.
No, no phones sold in Canada have radio tuners anymore.
No, no phones sold in Canada have radio tuners anymore.The LG G5 does have a radio tuner, it is just disabled by Koodo so that it cannot be used
No, no phones sold in Canada have radio tuners anymore.I should have specified working radio tuners sorry I apologize for not being more specific. Not sure why it's done exactly but been told it's not the carriers decision but the manufacturers themselves.
The last phone I owned that had an FM radio on it was the HTC M9. Even the 10 doesn't have it, and it's an unlocked model purchased directly through them. Sadly the carriers want you to spend more on data plans using streaming services.
Userlevel 3
LG G5 does have a FM radio chip (Its built into every Snapdragon 820 SoC) but its our carriers that disable it, possibly for the sake of forcing customers to use data (and thus pay more for plans).
Recently, T-mobile is US enabled the FM radio chip in the Galaxy S7 but you had to install a 3rd party app (Nextradio) to use it.
Its such a shame that carriers disable it because thats one less feature that should have been there and people do listen to FM radio.
LG G5 does have a FM radio chip (Its built into every Snapdragon 820 SoC) but its our carriers th...Here's one list of FM radio supported devices in Canada. They all require a separate app installation:
http://nextradioapp.ca/supported-devices/
LG G5 does have a FM radio chip (Its built into every Snapdragon 820 SoC) but its our carriers th...My G5 isn't on the list, but I can tell you it does work if you install a radio app, and it isn't using data or wifi (see below).
I just got a G5 and no FM radio app in the tools area. But I downloaded an FM radio app from Google Play (called 'Radio FM', and there are several to choose from), and it works fine. I don't have data at all, and it runs even when I switch off wifi, so it's definitely using whatever hardware is in the phone.
I just got a G5 and no FM radio app in the tools area. But I downloaded an FM radio app from Goog...Yeah most Samsung and LG Phones in Canada now have FM tuners built in just some don't have an app.
If we're talking about the same app, Radio FM requires data. As per the app developer: Radio FM (Radio for Mobile) is an app to play Internet Radio stations - meaning content is streamed over a data connection. The app may appear to work when disconnected from Wi-Fi because some of the apps information is buffered in memory.
https://play.google.com/store/apps/details?id=com.radio.fmradio&hl=en_US
A standalone FM tuner does not require a data connection. The tuner relies solely on radio signals broadcast from terrestrial FM radio stations.
Late in the thread, but for the record:
No luck with my LG G5 vs987 (unlocked but originally from Verizon, purchased used  on Amazon); I installed NextRadio but it shows “FM radio is Unavailable... does not have access to the receiver”. :(
Long aside, my BlackBerry DTEK50 has built-in FM radio, but also a native app from BlackBerry (simply called “Radio”, see screenshot), which shows RDS info for artist/song name, allows 6 presets as favourites, plus saves auto-scanned stations, each of which you can name (replaces “New channel 17” seen below). Listening now without SIM card and no WiFi. It was not purchased through any carrier; rather, new factory-unlocked from Amazon). Great implementation by BB of Android. Planning to replace the battery to go back.
