Does Koodo show mobile broadcast system alerts on android
Hey! I was wounding if Koodo show mobile broadcast system alerts on android. If not can you recommend a app that does thanks!
No Koodo doesnt. Not sure what your looking for exactly but if it's things like Amber Alerts and severe weather warnings & things of that sort then just check out and set up "Google Now" and you'll get all that stuff when applicable.
So is there a way to test this? Like I have the Nexus 5 and I have Google now Set up. Do I just wait and hope it works?
