Does Koodo show LTE,HSPI, or 4G on top of samsung galaxy s3(unlocked)?
Does Koodo show LTE or 4G on top of galaxy s3 (unlocked)screen, because mine doesn't. just switched to koodo from Telus and telus had LTE on top of screen
Yes it should
You need the APN settings in the phone to get data access, after which you'll see the symbols. https://c.getsatisfaction.com/koodo/topics/what_are_the_apn_settings_for_koodo_mobile?topic-reply-list[settings][filter_by]=all&topic-reply-list[settings][reply_id]=13671429#reply_13671429
Jonathan I wrote:
You need the APN settings in the phone to get data access, after which you'll see the symbols. ...
Or their 3G is working fine but just aren't able to pick up the LTE signal
Phone doesn't show any type of data signal
Thanks, did all settings, still no data info
Goto settings...wireless and networks..mobile networks Ensure data is enabled
Wifi off data on (no cap)
Try restarting the phone and MAKE SURE you put in the APN settings precisely. One wrong letter, number, or symbol and it won't work.
