Does koodo replace embedded batteries at all?
  • 27 October 2014
  • 2 replies
  • 113 views
Does koodo replace batteries at all? i have an HTC One V with a non-removable battery and it just died on me all of a sudden and now the battery won't hold a charge 😞 in the over 2 or so years i've owned it i've never had any issues with it so i'd like to keep it at least a bit longer so i can save up for a new phone in the mean time.
Nope. Koodo can send it in to the manufacturer for repairs and give you a cost. Personally, I would try to find someone locally to do it for cheaper http://help.koodomobile.com/getting-started-with-koodo/before-you-purchase/what-is-your-warranty-and-repair-policy
Personally I would just upgrade to a new phone since the one you have is 2 years old now and quite outdated. If your going to have a buy a battery anyways why not just upgrade using the tabaand get yourself a brand spanking new phone, just a thought. That phone dies have many known issues so I personally wouldn't put any money into it to extend its life.
