Does Huawei Meta 7/P8/P8 max can be used with Koodo plan?
I am looking forward to use Huawei on Koodo plans, I found 3 different phones on Huawei Website, can anyone help me to see if I can use them with Koodo plan? Thanks!! http://consumer.huawei.com/en/mobile-phones/compare/index.htm?pro1=ASCEND-MATE7&pro2=P8-EN&pro3=P8MAX-EN
Userlevel 3
Hey Durian,
Koodo's network frequencies are the following HSPA 850/1900 MHZ and LTE 1700/2100 Mhz.
Keeping this in mind and depending on the exact model, the Huawei Ascend Mate 7 (http://koo.do/1BnQPiO ), Huawei P8 (http://koo.do/1fhGlHT) and Huawei P8 max (http://koo.do/1fhGwTv) will work with Koodo on 3G and on LTE on band 4.
Hope this helps!
Veronica wrote:
Hey Durian,
Koodo's network frequencies are the following HSPA 850/1900 MHZ and LTE 17...
Thank you Veronica!! But do I need to unlock the Huawei cellphone if I buy it from China?
