Do the unlimited calls include incoming calls and outgoing long distance calls?
Hello Paul,
If you're on a Canada-wide plan, they do!
Long distance w/in Canada only, not to the US
Hope this helps!
Unlimited incoming, regardless of origin.
Outgoing unlimited Canada-wide, US is extra, and overseas is usually charged per minute with the exception of Koodo offering calling minutes add-ons for select overseas destinations.
On wifi or data, call the US free via Google Hangouts Dialer. If configured correctly, it'll display your Koodo number on your outbound call display.
Thanks for the inquiry, for my Package it is both incoming and outgoing calls covered and are unlimited .
Aslam wrote:
Thanks for the inquiry, for my Package it is both incoming and outgoing calls covered and are unl...
If you're on an unlimited nation-wide calling plan, then yes. If not, then no.
