Data won't work on Moto G
Help! I have the moto G and after a system update, my data is no longer there. There is just a cirlce with a line through it where the 3G symbol should be. And my APN is still there and correct for the network. What is wrong? How do I fix?? Thanks so much!!
Create a new apn using the settings found here http://koo.do/unlockedphone
Just had this problem with my moto g. Try turning off the wifi and then shutting down your phone with data on the turning it back on. If that doesn't work you'll have to create a new APN. Good luck hope this helps.
Thanks so much for the advice both of you! The data is now working... The data warning, limit, and time were mixed up. It is now working, however I get an H+ symbol a lot
