Data won't work
I bought a Samsung Galaxy S6 a month ago and have a plan that includes data. Mobile data setting is enabled on the phone and I have the APN set how the koodo website instructs but the data has never worked. When I try the built-in internet app I get the message, "Wifi and mobile data are turned off." But both are on and I only get internet access with wifi. Any help would be appreciated.
Hello Dark. Do.you have a data block on your account?
Never used any data at all, so I don't see how. And I never received a text telling me so.
I did indeed have a data block on by default and could not remove it from self serve, I'm not sure why this would be but it is now removed. Thanks so much.
Userlevel 4
Hey Dark! You can check in your Self Serve (http://koo.do/1TjB0RW) if you do have a data block. You can remove it yourself if it is there.
Let us know :)
[quote=Daniel]Hey Dark! You can check in your Self Serve ([url=http://koo.do/1TjB0RW]http://koo.do/1TjB0RW[/url...[/quote]We can remove ourselves?
[quote=Daniel]Hey Dark! You can check in your Self Serve ([url=http://koo.do/1TjB0RW]http://koo.do/1TjB0RW[/url...[/quote]Hey Robert, you're right, the data block can only be removed by calling us in.  Thanks for pointing that out!
