Data Won't Turn On
Have a Samsung Galaxy Ace II. When I turn data on, it allows me to click on but I am not actually connected and have to switch to WiFi where possible. This is a new problem. Everything worked fine for a year or so.
Have you tried restarting the device?
THANK YOU!!!Exact info I needed.
I am having the same issue. How do you change these settings? My phone won't let me edit any of the above fields.
In the Access Point Name menu there is a PLUS (+) sign at the top right to create a new one.
Do a fresh start under the name KoodoModified and type in the values above. Save and reboot.
Some phone models don't allow any changes. You will probably have to contact tech support if that's the case with your handset.
