Data usage problem in nexus4
how do i stop "android OS" in my nexus4 from keep getting my data usage? its being a problem for while
By turning your data off.
In that same menu, tap on 'Android OS' and then press menu > and tick 'Restrict Background Data'. That will not completely stop it, but it will largely help.
Keep in mind since you're restricting the OS from using Data you might run into some syncing problems with native Apps.
