Data usage problem in nexus4
how do i stop "android OS" in my nexus4 from keep getting my data usage? its being a problem for while
You have to have it running. It checks for updates and other system services. To totally stop data traffic for Android OS, you would have to block your data.
As I understood, it doesn't really count as data usage. Mine was showing 35mb when I was with Koodo with my 200mb plan and my data consumption was showing 15mb both on Android and the Koodo android app even though Android OS alone had a higher data consumption.
