data question
Hi everyone. I was wondering if you have to purchase an add on if you need more data per month or is a GB for 10$ automatically added when you go over? Thanks.
On prepaid you need to buy a booster for the amount of data you use and when you go over that you need to buy another booster. On postpaid it automatically brings you to the next level you don't need to do anything except pay for it when your bill arrives.
Thanks
