data plan issues
I bought 55$ plan including 2GB for my phone, but somehow its not working since I reactivated my phone. How can I fix this problem? Thanks for you kind service.
Hello Phillip Kim,
Did you already have data before that on your plan?
Robert wrote:
Hello Phillip Kim,
I did not have data before I got the plan thanks.
And has the phone been used on a different carrier before you reactivated it on Koodo?
I have changed my phone from LG G5 > LG V20
Make sure your APN settings are correct. Here is one link, but there are other descriptions to be found by searching 'APN' in the search bar.
