data not working once i changed phones
  • 15 September 2019
  • 2 replies
  • 93 views
My phone smashed so I replaced it. since I replaced it my data will not work. I've checked all phone settings to made sure the phone wasn't auto blocking it or something. Any idea why it won't work?
Best answer by Paul Deschamps 15 September 2019, 01:53
YYoure sure your using Koodo an settings in the app setting menu of the phone?
Heres the settings
APN: sp.koodo.com
Proxy: 74.49.0.18
Port: 80
Username: leave blank
Password: leave blank
Server: leave blank
MMSC: http ://aliasredirect.net/proxy/koodo/mmsc
MMS Proxy server: 74.49.0.18
MMS Port: 80
MCC: 302
MNC: 220
Authentication type: No set
APN type: No set
Tap menu key, then tap Save. Make sure the button to turn on data on the phone is selected to activate data. The frequencies are compatible with Koodo I'm guessing if it's not a Koodo device ?
Heres the settings
APN: sp.koodo.com
Proxy: 74.49.0.18
Port: 80
Server: leave blank
MMS Port: 80
MCC: 302
MNC: 220
APN type: No set
Is it a phone from Koodo? You'll probably need to reset your APN and make sure is all the Koodo settings.
