Data not working how fix
Kodoo prepaid got data but not working how to fix? Lg k4. Was with telus switched to kodoo. I set the apn removed sim card and battery and did a factory reset. Mobile network status is discounted but can use voice and text.
What did you set the APN to?
The koodo apn that I found on the forms
Can you post a screenshot of your settings?
Got it working it put spaces in it.
