data not working
  • 19 December 2013
  • 4 replies
  • 8 views
My date just stopped working
Userlevel 3
Unplug the battery and sim card for about 20 seconds. Plug back in turn back on the phone and try again. Also, in the settings make sure data is enabled and 3g is on.
Unplug the battery and sim card for about 20 seconds. Plug back in turn back on the phone and try...Thanks was the phone
Just to add, make sure your network settings are set to automatic and that your phone isn't set to use "2G" or "GSM" the only modes. Both settings can be found in... Settings... Wireless and networks... More... Mobile network
Thank you for your help
