Data issues
  • 30 September 2015
  • 7 replies
  • 12 views
Data won't work
A bit more info on that. I have a prepaid sim with a data booster, and yet it won't work. I am in a covered area, and I've never had any problems with this phone accessing mobile internet. What's going on?
What phone do you have?
Samsung galaxy S5 mini. It's unlocked, calls are working.
Samsung galaxy S5 mini. It's unlocked, calls are working.Check under access point names Make sure that koodo.sp is programmed and selected APN: sp.koodo.com Proxy: 74.49.0.18 Port: 80 Username: leave blank Password: leave blank Server: leave blank MMSC: http ://aliasredirect.net/proxy/koodo/mmsc MMS Proxy server: 74.49.0.18 MMS Port: 80 MCC: 302 MNC: 220 Authentication type: No set APN type: No set
Samsung galaxy S5 mini. It's unlocked, calls are working.I am not educated enough to follow those instructions.... If I go to sp.koodo.com it says not available. 74.49.0.18 says "This server does not serve any web content. Use the server for HTTP purposes." What do I do from there?
Samsung galaxy S5 mini. It's unlocked, calls are working.On your phone
Settings... Wireless and networks.... More... Mobile network... Access point names... Be sure koodo.sp is selected
Samsung galaxy S5 mini. It's unlocked, calls are working.I managed to do that, thank you for being patient with a n00b. I'll head out away from the hotel wifi and see if that has worked.
