Data connection not possible on LG
Hello, I am not able to access the data network on my LG phone, I've tried restarting, I've re-entered all the apn information, I have even done a factory reset and despite backing up my phone, lost all my contacts....needless to say I'm stumped. I have a prepaid account with plenty of data remaining. How do I fix this??
Hi Lisa,
Are you sure your baseplan is active?
Yes, it is active until June 3
I have same problem too.
Which LG phone do you have? Can you post screenshots of your APN settings?
I have an LG K7 , here are my apn settings
Lisa G wrote:
I have an LG K7 , here are my apn settings [img]https://d1qy7qyune0vt1.cloudfront.net/koodo-en/at...
APN type should be: default, MMS
Check the rest of your settings...
Especially MMSC as yours is wrong
You should check them against the correct settings
APN: sp.koodo.com
Proxy server: 74.49.0.18
Port: 80
Username:
Password:
Server:
MMSC: http ://aliasredirect.net/proxy/koodo/mmsc
Port: 80
MCC : 302
MNC : 220
APN type : default, mms Redo your settings, save them, and make sure your APN is selected . Then restart your device.
Still nothing unfortunately, changed the apn, saved and restarted phone.
Check settings> data usage and make sure mobile data is turned on
Make sure you don't have a data limit set on your phone.
Did you make sure the Koodo.sp APN was selected?
If there's more than one APN listed, try to delete all but the koodo.sp apn
Mobile data is on, no limit set, there is only one APN and it is koodo.sp and it is selected. I took my phone into koodo this morning and they verified all my settings.
Are you able to text and make phone calls?
Where did you buy your phone?
I am able to make phone calls, and standard texts. It is from Best Buy, I've had it for 6 months and it previously worked fine.
Try this, insert other friend sim card and should be your carrier send you a apn setting by text accept all and should you able to get i ternet. Then insert your sim. I did same and its work now.
