Data connection issue
I'm having data connection issues. I normally don't have my phone data enable on and I'm not able to get a connection this week. It was working last week so my APN setting is correct. My daughter is having the same issue. We're in Calgary
Problem solved. I cycled my phone (turned off/on) and did the job. I guess Telus/Koodo system had a hiccup.
L Wong wrote:
Problem solved. I cycled my phone (turned off/on) and did the job. I guess Telus/Koodo system h...
Glad it worked out
Userlevel 3
I'm in the same boat: I use Power Toggles to flip between wifi and mobile data (AutomateIt didn't work well for me) and I found that after a while (a week maybe?) mobile data stops working. I don't even get the icon in the upper bar. Only solution (as you discovered) is to reset the phone (power-cycle). Note3 on KK 4.4.2 here.
