Compatibility with Koodo?
  • 22 October 2020
  • 4 replies
  • 68 views
https://www.amazon.ca/Motorola-Moto-Power-Unlocked-International/dp/B087C9RVRG/ref=sr_1_3?dchild=1&keywords=Motorola+Moto+G8+Power&qid=1603372867&s=electronics&sr=1-3
Is this phone going to work on the Koodo network?
Yes it will work with the koodo network. See Motorola Moto G8 Power spec
https://www.gizmochina.com/product/motorola-moto-g8-power/
https://www.gsmarena.com/motorola_moto_g8_power-10052.php
GSM Arena is a good source for technical specs.
You can compare compatiability with specs here
https://www.koodomobile.com/en/help/my-phone-compatible-koodo
And you can compare LTE band n8umbers with frequencies here as Koodo uses Telus towers
https://www.signalbooster.com/pages/what-are-4g-lte-frequencies-bands-of-telus-rogers-bell
If you’re interested in that phone, Costco sells the North American variant for $299.99 (free shipping) online (likely about the same price as Amazon if available at your local Costco). If ordering online, you do not have to have a current Costco membership as it’s not labeled as a member-only item. Buying it from Costco will likely be less of a hassle if you should have any warranty issues (the Amazon listing specifies no US warranty and I’m guessing no Canadian warranty).
https://www.costco.ca/motorola-moto-g-power-unlocked-smartphone.product.100673567.html
@Philosoraptor
Thanks for the advice, I think I will go down that route and buy from Costco. Thanks everyone for all the replies, it’s much appreciated!
