Charger doesn't work on a 3 day old phone
I just got a new phone on a tab 3 days ago, and the box my charger plugs into, that came with my phone doesn't work, can I get a new one from the store?
Yes but bring everything back to the store as they may just do an exchange of everything.
Also does it matter if I go to the same store? As the kiosk I was at was far away, and I'm going to a different mall, much closer today anyway
Denise Alyssa Dobson wrote:
Also does it matter if I go to the same store? As the kiosk I was at was far away, and I'm going ...
Yes you must return it to where you got it. Honestly you can pickup another charging block for ten bucks at a couche tard or petro Canada. Might be less hassle.
Yea but it's a hassle that a new phone came with a broken charger. I shouldn't have to pay more then I already did
I hear ya and you can go back to the store. It's your choice really.
Hey there Denise!  Just to clarify, you can proceed with the exchange at any other Koodo kiosk if you originally purchased your device at a Koodo kiosk and you bring everything with you (including proof of purchase) If you purchased it at a retailer (Best Buy, Walmart ..etc) you will need to go back to that specific location.  Here's more information about how the warranty works http://koo.do/Kwarranty. Hope this helps :)
