changing phone device
Can I change phone device after regisrering the number on my old phone device. I need to do the transfer online!
Best answer by Paul Deschamps 29 April 2015, 20:56
Just pop out your SIM Card out of the old phone and put it into the new one, that is if it's the same size SIM Card. If it's a different size that you need for the new phone then you'll have to visit your local Koodo kiosk and purchase a new SIM Card that's the proper size. After you purchase the card just log into your self serve and click on the phone tab and swap mobile device, then input the new SIM Card # on the back of the card and pop it into the new phone and away you go.
1 reply
