CDMA phone
i have a galaxy s3 cdma from the us unlocked i can manually program the phone my self, questions is could i get a min and number so i can program them into the phone?
Unfortunately, only Koodo cmda phones will work with Koodo, Ivan 😞 You can't use your S3 unless it takes a SIM card and is unlocked 😞
Userlevel 2
Sophia wrote:
Unfortunately, only Koodo cmda phones will work with Koodo, Ivan 😞 You can't use your S3 unless ...
Sophia, what a good question. This phone uses a micro sim even though it's cdma. The bad thing is its frequencies.. 2G Network CDMA 800 / 1900 - SGH-I535, SPH-L710 3G Network CDMA2000 1xEV-DO - SGH-I535, SPH-L710 4G Network LTE 700 MHz Class 13 - SGH-I535 LTE 1900 - SPH-L710 http://www.gsmarena.com/samsung_galaxy_s_iii_cdma-4799.php Koodo frequencies HSPA 850/1900 MHZ frequency So even though that phones uses a micro sim. It will not work. 😞
