Can't send/recieve pictures!? Help please!
  • 4 September 2014
  • 2 replies
  • 20 views
I have a Galaxy S3 and can't send or receive pics even when Data is turned on on my phone. It says that "Network connection isn't available" when I attempt to send, and it says "cannot download picture at this time" when I try to receive. Picture messages are included in my plan. I don't have Data Block on my phone, I've tried being connected to Wifi, turning off wifi and just having data on, etc. etc. and nothing works. Any suggestions!?
Hi Kira! It sounds like something might be wrong with your phone's apn settings. Go to settings > Wireless & Network > Mobile Networks > Access Point Names. Change the apn settings to the correct ones or create a new APN and select it. The apn settings are in this link. 🙂 http://mobilemasters.koodomobile.com/the-comprehensive-guide-for-bringing-your-unlocked-device-to-koodo/
Hi Kira! It sounds like something might be wrong with your phone's apn settings. Go to settings >...Excellent summary on that blog! APNs are pain in the butt but seems to be the root of many issues.
