Can't connect to swisscom network. What is required
I'm in Europe and I can't connect to the European networks. What do I need to have to do that
Hello Judith,
Have you added the free international roaming package from self serve?
Robert wrote:
Hello Judith,
Yes it's on
Robert wrote:
Hello Judith,
It says it can't connect
Robert wrote:
Hello Judith,
It says my simple card does not support a connection
Robert wrote:
Hello Judith,
Sim card lol
You need to have pay per use international long distance and international voice roaming on to connect roaming. If you want data, you will also need international data roaming on. You can do this in self-serve. You can also do the same for roaming packages. Once that's done your phone should connect to a roaming partner, although I'd personally suggest having your phone unlocked and using a local sim, such as from Lycamobile.
Goran wrote:
You need to have pay per use international long distance and international voice roaming on to co...
Thankd
So you're saying the roaming add-ons have been turned on. Ok now try going into manual network selection, wait 1-2 minutes for the list to populate, and se eif you can connect like that. Also, what phone do you have?
Samsung s7..I don't require data so I didn't turn that on
Here's how to add the free international roaming packages. There's two of them :
Connect to sell serve and go to your add-ons
Click to change the add-ons
Search for 1) International Voice Roaming and 2) International Data Roaming
I don't require roaming just want to be able to call if I have to
You have to have them for anything to work. The two add ons are free
Thanks
