can't answer incoming calls
What phone do you have?make and model?
Samsung galaxy s III
Have you restarted the phone? Did you recently update the devices firmware?
No
Rosemarie R Ramsingh wrote:
No
Restart the phone Goto settings..about Scan for updates Try again
No
Thanks Chad worked! U rock. Have a good one.
No
Wait what did you do that worked? Let us know so if someone else has the problem they'll know what to do!
The phone rings but then nothing happens a green phone symbol joined to red phone signal tap green and red and nothing happens
The phone rings but then nothing happens a green phone symbol joined to red phone signal tap gr...
Maybe someone more familiar with the S3 will chime in but I believe you have to drag the green phone towards a phone symbol or the word "answer"
Found this in the S3's user manual. (Click on image to enlarge).
