can not receive phone call and text but I can make phone call and send massage
I can not receive any phone call and massage. However I can send and make call my self. I active my sim kart yesterday. I have this problem since the activation.
Make sure do not disturb or blocking mode is not enabled in your settings
Did you port your number from another provider?
This is a common symptom of a number port.
While the port is going through, you may only be able to make outgoing calls. Incoming will go to your old phone until it finishes.
Hi Fateme, are you able to receive calls and messages now? Keep us updated!
