Can koodo help
  • 16 April 2014
  • 2 replies
  • 9 views
My phone is broken can Koodo do anything with my working parts of my phone.
Not really, no... Looks like you'll have to seek out a repair shop or upgrade your device. Try calling the loyalty department to see if they can cut you a break on the Tab (if you have one).
If you decide to upgrade instead of repairing your phone, you should check out the moto g. It's 150 outright on postpaid or free on tab s. It's a really good phone, especially for the low price tag!
