Can I use a add on as a plan
My question is if I can use a add-on booster as a plan? Also what is the minumum prepaid plan
Userlevel 3
Minimum prepaid plan is $15 a month. That gets you unlimited text only.
No, prepaid requires a minimum base plan. Boosters are extra on top. The minimum base plan is $15/mo for unlimited text. If you need calling, you add a booster for Canada wide minutes or go up to at least a $25 base plan that has unlimited evenings/weekends.
