Can I keep same number when I upgrade to a phone using different size of sim?
I want to upgrade from moto g to moto x play . Can I keep my same phone number as I have to change my present micro sim to nano sim in moto x play? If I order through self serve the nano sim will be included with the package ?
The sim either is included or you have to pay 5$ for it and it will be. Someone else will undoubtedly correct me on that one.
You can absolutely keep your number. You just use selfserve to transfer the service to your new sim number. Just look for the link to phone services in self serve.
It's free and takes fifteen minutes to transfer (or less).
Chad Burr wrote:
The sim either is included or you have to pay 5$ for it and it will be. Someone else will undou...
Thanks Chad, I have done the order through self serve and didn't get an option topay for the nano sim. Hope it will be there with the package
