Can I get my charging cable replaced after my cat chewed on it?
I have a phone from koodo under warranty and was wondering if I can get the charging cable replaced due to wear and tear resulting from my pet?
Hi Omair,
No, that would fall under accidental-type coverage which is never included with any device warranty.
Mathieu wrote:
Hi Omair,
No, that would fall under accidental-type coverage which is never included with any de...
However charge and sync cables can be found relatively inexpensively at a local c store or dep. Amazon sells them too. Stock up.
Userlevel 4
Mathieu wrote:
Hi Omair,
and if you have time to wait, monoprice.com (from the states) has some really awesome prices, even after exchange rates
Mathieu wrote:
Hi Omair,
Shopperplus.com is the Canadian equivalent, if you are looking for a more local solution.
