Can a Bell Sony Xperia Z5 work on Koodo network if unlocked?
I was looking to see if the new Sony Xperia Z5 "exclusive to bell" could be unlocked at a Koodo station. Is it supported on Koodo?
if you know the phone's IMEI, use it on this webpage to see if it'll work with Koodo.
http://help.koodomobile.com/getting-started-with-koodo/sim-cards-and-non-koodo-phones/how-do-i-know-...
Also, look up the specs for the phone and see if the network it supports includes Koodo.
Use GSM arena to look up the phone specs and network specs and compare it against http://help.koodomobile.com/getting-started-with-koodo/sim-cards-and-non-koodo-phones/Will-my-phone-...
Yes, a Sony Xperia Z5 from Bell that is unlocked will work on Koodo 🙂
Yes it will thay are both LET combatble make sure you scurity scan your phone ones uunlocked there my be Chace hackers can get in to it should work if not then phone is not compatible
If unlocked than yes or else only telus phones works on koodo being a part of same family. Moreover, any android phone can be unlocked easily from any tech shop in few $...
