Camera shutter noise turn on
Any idea on how to turn on the camera shutter noise, I have looked in settings and can't find it anywhere ?
Did you look in the settings in your actual camera app? If not it's in there if you have one. what phone do you have?
It has to be on the settings, at least it is on the S II X, what kind of phone do you have?
My phone is the S3
Craig McDowall wrote:
My phone is the S3
It should make the shutter sound by default. I don't use my camera much on my Galaxy Note 2 but I think k it's the same as the Galaxy S3. On mine it's just on by default. Try going into settings and at the very bottom click reset, this should reset all your camera settings and if the shutter sound is by default like mine then it should bring it back. I can't find a way to turn it on or off at all right now. If I find it I'll let you know but try reseting the camera settings and let me know if that works.
My phone is the S3
Thank you for this
Thanks for all the advice everyone, managed to get it sorted out
What fixed it?
