Call Forwarding Cost? (pay per use - NO add-on)
Hi! How much does it cost to forward calls to another Canadian number when there is no signal (or phone switched off)? I know that it costs 3$ for the add-on, but I don't need the add-on. I just want to know the rate for each call forwarded. Thanks!
It depends on your plan, but it is typically $0.50 per minute
You may well say you don't need the add-on, but those toll charges add up quickly. Anyone who calls you while forwarding is active (wrong number, telemarketer, or just plain forgetting to turn it off) will ring up Koodo's cash register.
I forwarded my Android phone to my Samsung watch phone number( to answer if no response on Android) Forgot, went out of town for about a week without my watch....everyone kept saying "I left you a voicemail"... I'd say NOPE. Finally called to check it out and there was about $30 worth on my bill.... ¢.50 ? I vaguely remember, but think it was $1.50 per call.... They credited me the $30 for the mix up....it should have message telling you there is fees when you turn forwarding on...good thing only a few calls where missed and sent to watch...bill could of been hundreds
Mack Jones wrote:
I forwarded my Android phone to my Samsung watch phone number( to answer if no response on Andro...
Nope. $0.50/minute is the right rate. You do get charged a minimum of one minute for every call that's forwarded though, whether they leave a voicemail or not.
