call forwarding and texts
Will my texts be forwarded as well as my calls?
The option is called "Call Forwarding" so I don't think texts will be forwarded as well. But I'm not 100% sure.
The option of forwarding call on Koodo is for voice only, I believe. And it is not free, unless you have call forwarding option add-on.
For text, there are options depending what phone you are using. Apple iPhones can forward texts to another ios devices. Android phones need separate apps.
