Call forwarding
  • 18 August 2015
  • 7 replies
  • 176 views
Hi there, I need call forwarding to my assistant before I go on vacation. I need to take my phone with me for internet access. How do I set this up ?
There's a monthly add-on for $3 that covers this. Otherwise, you'll be dinged a toll amount every time a call is forwarded, something like 35 cents a minute.
Calls can only be forwarded to Canadian numbers without incurring extra charges. Treat this like you would the 11th commandment.
Here's the nuts and bolts: http://help.koodomobile.com/plans-add-ons-data-and-other-services/calling-features/how-do-i-use-call-forwarding
You can still use your phone for outgoing calls and data while forwarding is active.
Have a nice vacation.
Userlevel 3
There's a monthly add-on for $3 that covers this. Otherwise, you'll be dinged a toll amount every...Hey there,
Bob is right! I would just like to make a little correction. If you are not covered by the Call forwarding Add-on, beside regular airtime, forwarding your calls will cost $0.50/minute.
Thanks!
There's a monthly add-on for $3 that covers this. Otherwise, you'll be dinged a toll amount every...The price went UP from 35 to 50 cents. Why are we not surprised?
There's a monthly add-on for $3 that covers this. Otherwise, you'll be dinged a toll amount every...This is robbery. 50 cents a minute. I freaked when my bill came in. I'm forwarding to a local phone number and they charge 50 cents a minute?
There's a monthly add-on for $3 that covers this. Otherwise, you'll be dinged a toll amount every...can we forward calls to canadian homephone number while on seasonal hold ?
can we forward calls to canadian homephone number while on seasonal hold ?No. The seasonal hold simply keeps your account in stasis, so it can be revived on your return. No activity of any sort can occur while on the seasonal hold plan.
