Best answer by David AKU
No. Call forwarding has to be done from the phone. If you have your SIM, you can insert it in another phone and set up call forwarding. If you have lost the SIM as well, you can obtain a SIM from a Koodo vendor, validate it through self serve, and follow the steps above.
You can access your voicemail from another phone and retrieve messages.
