busy tone wen I try make outgoing call..but recieve incoming calls fine
  • 24 January 2014
  • 24 views
(empty)
Maybe trying to power off the phone off and back on and try again
Is it every time you make a call that you get a busy tone?
Make sure to dial the full 11 digit phone #, like 1-705-555-5555
I experienced this a couple of times yesterday and the day before with my iPhone 4s and Moto G with a couple of 1-800/866 numbers I call that dial out perfectly otherwise. Waiting a few seconds and redialing the number solved the problem. As of today, I'm not having any problems with the busy signal.
There may be signal problem
