Bug in Public Wifi
  • 15 June 2019
  • 2 replies
  • 63 views
When my data used was at 100% I went to Public Wifi spots.
At these spots I have to first connect and then click that I accepted the conditions.
The bug is when I accepted the conditions Kodoo would then deny the WIfi connection.
How do you know Kodoo denis the WIfi connection?
Make sure you turn off your data while you're trying to connect to wifi in case things get screwy.
