bluetooth messaging with Hauwei p30 lite
I don't understand why I cannot get messages in my car with bluetooth? Is this a problem with this phone?
Try to figure it out with the info in the following link https://en.admininfo.info/c-mo-solucionar-problemas-bluetooth-huawei-p30-lite
It sounds like it should work. But it doesn't.
What kind of car do you have?
Are you using the Android Auto app.? Do the phone and media work in your car?
I have a ford edge
 The phone connects with sync. Phone works for calls. Just not messaging
But sure what you mean by auto app
I could read my messages when I first synced it but then it said it wasn't capable of messaging when I turned the car in the next time
Is the ‘Auto reply.’ enabled in your app settings?
In that case can you try completely removing your phone from the car and reconnecting it from scratch?
I did try to remove and add again. Didn't change it. Don't see anywhere to set auto reply
I was referring to Android Auto setup. You may try to search ‘message issues’  specific to Android and your Ford Edge car’s version of Ford SYNC.
Perfect will try that. Thanks so much.
