blue tooth connection
  • 27 June 2019
  • 2 replies
  • 26 views
Hi everytime I try to connect with nearby devices for blue tooth with my Samsung Galaxy S7 it always says cannot connect
You can try forgetting the connection and do a new connection with those devices. If it won't work you can try resetting network settings, which will clear all saved network connections. You'd go into backup and reset in settings, reset network settings. If it still won't work you'll probably have to back up your phone and then wipe cache partition:
https://forums.tomsguide.com/faq/how-to-resolve-bluetooth-connectivity-issues-on-the-galaxy-s7.107910/
Have you tried to connect to your device via other phones?
