blocking mode not working on my samsung galaxy s3. how do i fix this?
  • 7 October 2013
  • 3 replies
  • 6 views
I really like this idea but I still receive unwanted emails when in blocking mode. I am sure i got it set up correctly and i only have 4 allowed contacts. is this feature a joke? Any apps for this i can use instead of the one on 4.1.2?
The blocking mode can disable email email notifications, however emails will still be received regardless who it's from. It's like a Do Not Disturb mode
well the vibrate is still working
well the vibrate is still workingAre you using the default email app or the gmail app? After some reading it turn out that others are also having issues with emails still vibrating while in blocking mode. You might have to turn off vibrate manually. I know, it's not really a solution but a work around :s
