block someone from texting
how do i block someone from texting a thousand times? i blocked his number, so he cant call, but he still can text me every minute..help!
I use Extreme Call Blocker from the Google Play Store.
Give it a look : http://droidlessons.com/how-to-block-unwanted-calls-text-messages-on-android/ Or there is the possibility to ignore his texts. He will abandon after a while if he's bright enough.
If all else fails then change your phone #. It might suck having to get all your friends to add you back but if he gets very harassing then it's a last resort option.
Userlevel 2
Ask Koodo if they can find out his provider because I bet that violates their TOS.
