Billing cycle on phone doesn't match bill
  • 18 September 2019
  • 8 replies
  • 203 views
Hi everyone,
I had a shared account with my (now ex) girlfriend. She was the account holder, but 2 weeks ago transferred the entire account to me. Then disconnected her phone.
Previously our billing cycle was 12th of month to 11th of the next month.
But, now my billing cycle is the 6th to the 5th.
My problem is that my phone is only reporting I used 3.5 MB, but I just got a text saying I've used 30 MB.
How can I get my phone to match my account?
I tried using the robot chat and after 15 minutes, it couldn't figure out my problem.
Any help would be awesome!
Thanks!
MK
Best answer by Timo Tuokkola 19 September 2019, 00:37
Have you tried with cellular data turned on? As I recall certain features are unavailable if it is not.
Settings>Connections>Data Usage
Here you can change the billing cycle date on your device to what it actually is in real life
Hi Dennis,
Thanks for the response.
I went into "Settings", but I don't see anything called "Connections".
There is an option called "Data Usage", but I don't see how/where to change the dates.
There is a drop menu showing Sep12-Oct11, with 3 previous months of similar dates.
But my new billing cycle is the 6th to 5th.
Anything else I can try?
My phone is a Moto G, using Android 5.1
Thanks for trying to help 🙂
Hi Dennis,
Thanks for trying to help :)
Go into Data usage and there should be a menu to change or edit the dates.
Try clicking on the dates or look for a "..." more options button
Here's where it would be on my phone. You're looking for something like "reset on", or "cycle date"
Hi everyone,
Thanks for the responses, but it seems that my phone is unable to edit this.
https://i.imgur.com/2icOg47.png
https://i.imgur.com/Wl1n4CT.png
https://i.imgur.com/nUAhNeh.png
I will go to the mall and ask a sales rep to help me.
But, I have a feeling it's not possible to edit.
Thanks anyways.
Michael
OMG!! That worked!!
Thanks Timo!!
Just to show the comparison with data on vs. data off
Data off:
Data on:
https://i.imgur.com/NUBbkID.png
Then I was able to update 🙂
